Hỏi về Windowxp home muốn có IIS
Các thớt khác của heine
2 Tháng ba 2007 lúc 15:56
Mình mua máy laptop sony vaio có win xp home có bản quyền. Nhưng mình đang làm về IIS (Internet Information Sevices) hình như chỉ có trong bản professional.
Có cách nào setup nó vào trong bản Win home này cho đỡ phí bản quyền không?
Những cách như xài win xp pro 8k , hay mua chính hãng thì hông nói làm gì. Mình chỉ muốn làm sao setup để cho win này có thêm cái IIS đó thôi.
Bạn nào có kinh nghiệm thì chỉ giúp mình nhé. Cám ơn rất nhiều.
mkford
2 Tháng ba 2007 lúc 16:12
Tìm hộ bạn cách step by step nè:
1/ You will need the installation CD of Win2000 Professional or Server (winXP Pro CD WILL NOT work) or a trial version of Windows 2000 Server - See the FAQ's at the bottom of this page
2/ If you don't have 2 cd-rom players I suggest you to copy the directory i386 from the WinXP Home on your hard disk
3/ In this directory (i386) there is a file called IMS.CAB with WinRar (or something similar) unpack the content to a temporary folder (you will need them at the end of the installation)
4/ Search for and find the file: c:\WINDOWS\INF\SYSOC.INF
5/ In the section [COMPONENTS] you will find this line: iis=iis.dll,OcEntry,iis.inf,hide,7
6/ Change it to this: iis=iis2.dll,OcEntry,iis2.inf,,7
(remember to change the name in iis2.dll and iis2.inf and to eliminate the word hide. In this way you bypass the protection of XP home)
7/ From the Win2000 cd (Pro or Server) take the files: iis.dl_ and iis.in_ that are in the i386 folder and copy them on your desktop, open a dos windows and with the prompt pointing at your desktop edit the following commands:
EXPAND IIS.DL_ IIS2.DLL
EXPAND IIS.IN_ IIS2.INF
this will generate two new files named iis2.dll and iis2.inf
copy and paste IIS2:DLL to c:\WINDOWS\SYSTEM32\SETUP\
and IIS.INF to c:\WINDOWS\INF\
8/ Go to control panel/application/windows components (I don't have an English version of Windows so I don't know exactly the name) and start windows installer. You will see "Internet Information server" is now available as a checkable option.
9/ Select it (I suggest that if you are looking only for PWS to select only that because the more components you install the more files you have to search for)
10/ It will need about 10/15 minutes and during that time the system is going to ask you for a lot of files: some are in XP Home CD other in Win2000 CD. At a certain point the system will ask you for the EXCH_adsiisex.dll file: it is the file you have extracted at the point 3 of this guide, select it and you should go on without trouble.
11/ At the end restart you computer.
12/ Test if it is working: open Internet Explorer and type in the address line: http://localhost
13/ If it will not work, try the following:
open a DOS window and type: iisreset /RESTART
go to web proprieties in "directory protection" (I don't know if this is the exact name on an English version) click on "modify" (or edit, as said before I don't have an English version ...) "browse" and finally"find". You will see all user in your PC. Select the one you are working with and click OK. In the text-box you will see PcName\UserName. Click OK to close the window. Remember to uncheck "password Control) and click OK three times. Close and restart the web server and retry point 12. If all is correct you will see the default presentation page of IIS 5 and the online help
Good luck.
2 Tháng ba 2007 lúc 17:30
hix tình hình là mình không có cái cd XP Home. Vì nó nằm trong recovery của HDD laptop luôn. Máy không có CD Windows kèm theo. Vậy phải đi mua Win xp home cd ah`.
Hix phức tạp thiệt. :D chắc chơi đĩa 8k cho nó lẹ quá. :(
mkford
2 Tháng ba 2007 lúc 18:01
Cần đĩa Windows 2000 cơ mà ( mất 8K nữa bây giờ :D)
pires751
Nikonian
2 Tháng ba 2007 lúc 18:03
Cái cách của bác MKford search trên google ra nhưng hình như bác chưa thử thì phải. Em trước đây cũng dùng XP HOme cứ tiếc cái license và làm hệt như hướng dẫn trên, đi mua hẳn đĩ win 2000 về. ặc ặc, loay hoay 1 hồi, chả được tích sự gì, gõ localhost chả ra cái gì cả --> nếu bác đã dùng win HOme thì cách tốt nhất là upgrade lên pro để có IIS thôi.
3 Tháng ba 2007 lúc 01:51
Không dùng IIS được không? Nếu bác muốn cài webserver thì xài cái này http://www.appservnetwork.com/. Sau khi setup xong bác sẽ có luôn MySQL (chắc là 5.0), Apache, mysqlmyadmin. Sau đó làm web thoải mái, hehe
Phần mềm quản lý nhà in ra đời đã trở thành cứu cánh cho các nhà in cũng như nhân viên và lãnh đạo ngành in. Phần mềm quản lý chuyên nghiệp dùng để thiết kế dành riêng cho nhà in nên sẽ có những tính năng chuyên biệt chẳng hạn: offset sách báo, catal ...
