Máy của tôi muốn down họ bảo kick phải chuột rồi save target as. Nhưng bấm chuột phải không thấy có gì hiện ra cả. Khi xem trực tuyến thì nó cứ báo lỗi, cụ thể là lỗi:
C00D1197: Cannot play the file
Windows Media Player cannot play the file. You might encounter this error message for one of the following reasons:
Your computer is not connected to the local area network (LAN) or to the Internet. Connect to the network or Internet, and then try again.
The path to the file is not valid. If you typed a Uniform Resource Locator (URL) in the Open URL dialog box, verify that the file name is spelled correctly and that the path to the file is correct, and then try again. If you clicked a link on a Web page, the link might not be valid.
The server is not available (for example, the server is busy or not online). Try again later.
Some network protocols in the Player are not enabled. Enable all network protocols, and then try again.
The proxy server settings for the Player are not configured properly. Verify that your proxy settings are correct, and then try again.
To enable all network protocols
On the Tools menu, click Options, and then click the Network tab.
In the Streaming protocols area, select all the protocol check boxes.
To verify your proxy server settings
Verify your settings in the Streaming proxy settings area.
Note
If you do not know what your proxy server settings should be, on the Network tab, select a protocol, click Configure, and then select Autodetect proxy settings or Use proxy settings of the Web browser (available for HTTP protocol only).
Error ID = 0xC00D1197, Condition ID = 0x00000000
Chán quá! Có bác nào biết giúp Em với ạ!!!
