Download leaked OS 5.0.0.314 For the 8900 or download here
[FIX] SMS Not Sending On OS
Figured out how to fix the SMS Not Sending Problem
Note: Not everyone may have this problem and probably only t-mobile customers are having it I dont know.
Ok so here are the steps that I performed in order to fix the SMS Not sending problem. (I ran multiple tests and this was the only way i fixed it)
Steps:
Goto: Settings/Options/Advanced Options/ Host Routing Table and select to register
Turn off Network Connections after it registered
Now Hold alt and type l g l g ( Hold Alt + Tap L,G,L,G )
Now select menu and clear the logs
Final Step Do a Quick Pull (Let it Last atleast 30 Seconds to clear some flash memory)
After Re-boot:
Let the Device connect to the network leave it for about 30 seconds aswell then go ahead and start texting again.
Steps:
After Re-boot:
