Số là mình cài lại windows XP bản tiếng Anh từ máy mua về từ Nhật. Do đó phải cài lại driver cho ổ cứng SATA, nhưng khi cài xong thì vào BIOS không biết làm thế nào để Enable cái SATA đó
. Mong mấy huynh chỉ giáo. Thanks so much.
Tiện thể mình chia sẽ luôn hướng dẫn
Here's how:
1) Download the Intel Matrix Storage Manager here:
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2101&lang=eng
2) Once you download the file, run it with a -a switch:
iata76_enu.exe -a
This will NOT install the Matrix Storage Manager. What this will do is
run the installer, and ONLY EXTRACT the files to C:\Program
Files\Intel\Intel Matrix Storage Manager. Again, this does NOT install
anything.
3) Your drivers are now located in C:\Program Files\Intel\Intel Matrix
Storage Manager. They will be found in either \Driver, or \Driver64,
depending on whether you're running a 32-bit or 64-bit OS.
4) Go to Device Manager --> IDE ATA/ATAPI controllers. Double-click on
the Intel ICH8M 3-port SATA Controller - 2828... remember, *ONLY*
click on the device that ends with 2828.
5) Go to Driver tab, and choose to Update Driver.
6) Tell the Wizard prompts:
- No, not this time
- Install from a list or specific location (Advanced)
- Don't Search. I will choose the driver to install.
- Click the "Have Disk" button. Point it to C:\Program
Files\Intel\Intel Matrix Storage Manager\Driver (or Driver64).
- The driver you want to install for WinXP 32-bit for the Dell XPS
M1330 is Intel 82801HEM/HBM SATA AHCI Controller
- After you install the driver and click OK out of every menu, reboot
the laptop.
7) During reboot, go into BIOS and turn on AHCI mode and Flash Module
8) Voila! WinXP will boot up with no BSOD!
Here's how:
iata76_enu.exe -a
anything.
- No, not this time
the laptop.
