XTreme Tweaks v1.0
Công cụ tùy biến trên PPC
Ứng dụng tốt nhất cho Windows Mobile 6.5 tuỳ biến / cá nhân hoá. Dễ sử dụng, ngón tay thân thiện, KHÔNG CẦN STYLUS!.
Hỗ trợ VGA và WVGA!
Download :XTreme Tweaks v1.0, best tool for Windows Mobile 6.5 personalization/customization. Easy to use, finger friendly, NO NEED FOR STYLUS!.
Available in both VGA and WVGA Resolution!
--GUI Tweaks--
1.Start Menu Columns - Allows you to choose how many columns you want in Start Menu.
2.Scroll Bar - Choose how your scroll bar will look like. The change can be visible in Phone, File Explorer, etc.
3.Phone Keypad - This option allows you to set the theme for Phone keypad. The change can be visible in Phone.
4.ClearType - If ON, ClearType will be activated.
--System Tweaks--
1.SMS Sent Message - If OFF, this option will disable the SMS sent message.
2.STK Services - If OFF, this option will disable the SIM Operator (Network Operator) options. This will not set your Phone into Flight Mode. The change can be visible in Start Menu - your Network Operator icon.
3.Increase Font Cache - If ON, font cache will be increased.
4.Increase TCP/IP Cache - If ON, TCP/IP cache will be increased.
--Other Tweaks--
1.SIM Contacts - If HIDE, all SIM contacts visible in Contacts will be hidden.
2. Auto-Lock - If ON, your Phone will auto-lock after 50 seconds or at power button press.
3. SMS Threading - If OFF, SMS Threading will be disabled. This change can be seen in Text/Messaging at your messages.
4. Customer Feedback - If OFF, Customer Feedback will be disabled.
5. Error Reporting - If OFF, Error Reporting will be disabled.
6. In Call Recording - If ON, this option will allow call recording, see the option available when making a phone call. The recording will be saved in My Voices.
7. Right SoftKey - This option is visible with Windows Default as Today at the right Softkey.
8. SmartTouch - If ON, SmartTouch will be available in most programs.
MORE FEATURES
- Finger Scrolling !
- Big Icons/Buttons, finger friendly, no need for stylus !
- Landscape Support !
- Cool Graphics
- Most Daily Use Functions
- EASY to USE !
- Rapid menu access
- Help
- Restart Device
- Restore To Default
- .PNG Start Menu Icon
More Info:
http://www.smartphone.net/software_detail.asp?id=5873
Mã:
[/URL][URL="http://anonym.to/?http://www.megaupload.com/?d=5LTIIM86"]http://www.megaupload.com/?d=5LTIIM86[/URL][URL="http://anonym.to/?http://www.megaupload.com/?d=5LTIIM86"]
